Introdução
This guide will walk you through the necessary steps to remove the lens peice in the Nikon Coolpix E5700.
O que você precisa
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Turn to the bottom of the camera.
Remove the two Phillips screws located directly below the back monitor
Finish pulling away the back panel.
Turn the camera to its non-grip side.
Remove the Phillips screw located above the strap holder.
In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
3 outras pessoas executaram este guia.
Um comentário
bonjour,
je viens vers vous pour vous demandez OU je vais trouver les pièces pour remettre en état j'ai un Nikon Coolpix 5700 il a l'écran tout noir sur l'écran tout noir juste le paramètre de l'appareille.
je n'arrive pas a trouver le pièce sur quel cite je pourrais trouvé sais pièces
je tient beaucoup a mon appareil
merci de me renseigné cordialement
