Ir para o conteúdo principal
Nikon Coolpix B700 Motherboard Replacement
O que você precisa
  1. Nikon Coolpix B700 Motherboard Replacement, Back Frame Assembly: passo 1, imagem 1 %32
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Motherboard Replacement: passo 3, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 3, imagem 2 %32
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Motherboard Replacement: passo 5, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 5, imagem 2 %32 Nikon Coolpix B700 Motherboard Replacement: passo 5, imagem 3 %32
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Motherboard Replacement: passo 6, imagem 1 %32
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Motherboard Replacement: passo 7, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 7, imagem 2 %32
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Motherboard Replacement, Internal Bracket: passo 8, imagem 1 %32
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Motherboard Replacement: passo 9, imagem 1 %32
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Motherboard Replacement: passo 10, imagem 1 %32
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Motherboard Replacement: passo 12, imagem 1 %32
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Motherboard Replacement: passo 13, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 13, imagem 2 %32
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Motherboard Replacement: passo 14, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 14, imagem 2 %32
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Motherboard Replacement: passo 15, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 15, imagem 2 %32
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Motherboard Replacement, Motherboard: passo 16, imagem 1 %32
    • Use the metal spudger to open the latch to remove the ribbon.
  17. Nikon Coolpix B700 Motherboard Replacement: passo 17, imagem 1 %32
    • Use the Phillips screwdriver to remove the single 6 mm screw.
  18. Nikon Coolpix B700 Motherboard Replacement: passo 18, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 18, imagem 2 %32
    • Gently lift the button assembly. Slide the motherboard out from the shell.
  19. Nikon Coolpix B700 Motherboard Replacement: passo 19, imagem 1 %32 Nikon Coolpix B700 Motherboard Replacement: passo 19, imagem 2 %32
    • Desolder the black, gray, and white wires from the motherboard.
    • The motherboard is labeled with the wire colors.
Conclusão
Um comentário
Nikon b700 all sorts part demegs
Rathod Umesh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 686
