Ir para o conteúdo principal
Nikon Coolpix B700 Button Assembly Replacement
O que você precisa
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: passo 1, imagem 1 %32
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: passo 2, imagem 1 %32
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: passo 3, imagem 1 %32 Nikon Coolpix B700 Button Assembly Replacement: passo 3, imagem 2 %32
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: passo 4, imagem 1 %32
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: passo 5, imagem 1 %32 Nikon Coolpix B700 Button Assembly Replacement: passo 5, imagem 2 %32 Nikon Coolpix B700 Button Assembly Replacement: passo 5, imagem 3 %32
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: passo 6, imagem 1 %32
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: passo 7, imagem 1 %32 Nikon Coolpix B700 Button Assembly Replacement: passo 7, imagem 2 %32
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: passo 8, imagem 1 %32
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: passo 9, imagem 1 %32
    • This should remove the entire assembly from the camera housing.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 25
Duração total: 458
