Ir para o conteúdo principal
Nikon Coolpix AW130 Shutter Button Replacement
O que você precisa
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: passo 5, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: passo 5, imagem 2 %32
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: passo 6, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement: passo 6, imagem 2 %32
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: passo 7, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: passo 7, imagem 2 %32
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: passo 8, imagem 1 %32 Nikon Coolpix AW130 Shutter Button Replacement: passo 8, imagem 2 %32 Nikon Coolpix AW130 Shutter Button Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,091
