Ir para o conteúdo principal
Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement
O que você precisa
  1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: passo 5, imagem 1 %32 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: passo 5, imagem 2 %32 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: passo 5, imagem 3 %32
    • Using the spudger, pry the plastic button face from the camera body.
    • The sharp edges of the spudger could cut you or pierce an exposed battery.
  6. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
  7. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: passo 7, imagem 1 %32
    • Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
    • From there, the buttons should dislodge from their plastic casing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 680
