Ir para o conteúdo principal
Nikon Coolpix AW130 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, imagem 2 %32
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: passo 6, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: passo 8, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: passo 9, imagem 1 %32
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, imagem 2 %32 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, imagem 3 %32
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: passo 11, imagem 1 %32 Nikon Coolpix AW130 LCD Screen Replacement: passo 11, imagem 2 %32
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: passo 12, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Conclusão
8 comentários
Hi.
Where can you buy a replacement screen?
Ben - Responder
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Responder
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Responder
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Responder
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 2,977
