Ir para o conteúdo principal
Nikon Coolpix AW130 Battery Replacement
  1. Nikon Coolpix AW130 Battery Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 Battery Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 Battery Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
Conclusão
Um comentário
Try the following before ordering your battery :
The problem with my cool pix aw130 was the little yellow plastic tab ( seen in one of the above photos ; step 3 ) that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
Franklin Noel Stein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 33
Duração total: 2,401
