Ir para o conteúdo principal
Nikon Coolpix AW130 Battery Door Replacement
O que você precisa
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 Battery Door Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 Battery Door Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 Battery Door Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: passo 5, imagem 1 %32 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: passo 5, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: passo 6, imagem 1 %32
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: passo 7, imagem 1 %32 Nikon Coolpix AW130 Battery Door Replacement: passo 7, imagem 2 %32
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: passo 8, imagem 1 %32
    • Pull the battery door away from the camera body.
Conclusão
Uma outra pessoa concluiu este guia.
6 comentários
Where can I purchase the battery cover?
Thanh Tran - Responder
Where can I buy the AW130 battery door?
Jose - Responder
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - Responder
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - Responder
Need web site to order battery door?
Connie Mossor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 4,143
