Ir para o conteúdo principal
Nikon Coolpix AW130 Back Panel Replacement
O que você precisa
  1. Nikon Coolpix AW130 Back Panel Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix AW130 Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Back Panel Replacement: passo 2, imagem 1 %32 Nikon Coolpix AW130 Back Panel Replacement: passo 2, imagem 2 %32
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Back Panel Replacement: passo 3, imagem 1 %32
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Back Panel Replacement: passo 4, imagem 1 %32 Nikon Coolpix AW130 Back Panel Replacement: passo 4, imagem 2 %32
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Back Panel Replacement, Back Panel: passo 5, imagem 1 %32 Nikon Coolpix AW130 Back Panel Replacement, Back Panel: passo 5, imagem 2 %32
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 Back Panel Replacement: passo 6, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 Back Panel Replacement: passo 7, imagem 1 %32
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 Back Panel Replacement: passo 8, imagem 1 %32 Nikon Coolpix AW130 Back Panel Replacement: passo 8, imagem 2 %32
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 Back Panel Replacement: passo 9, imagem 1 %32
    • Carefully remove the back cover from the camera body.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
Did this to inspect the inside of the zoom lever, which is broken and will (only with difficulty) zoom in, and won't (at all) zoom out.
Followed the instructions to the letter but, after all screws removed, was unable to get the back panel separated from the body of the camera. Either there is glue, or some sort of latching mechanism present - or something missing in the description. Didn't want to break anything completely, as camera is still just about usable - so I gave up. I don't think the camera will be water-proof any more after this.
Jason Wolfe - Responder
Does anyone know where I can order an Coolpix AW130 rear panel?
Joel Dean - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 2,544
