Ir para o conteúdo principal
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Nikon Coolpix 995 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: passo 2, imagem 1 %32
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: passo 3, imagem 1 %32 Nikon Coolpix 995 Memory Card Replacement: passo 3, imagem 2 %32
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Conclusão
Uma outra pessoa concluiu este guia.
Cory Layman
Membro desde: 10/04/11
89 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team 1-5, Zhou Fall 2011 Membro de UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 2,267
