Ir para o conteúdo principal
Nikon Coolpix 995 LCD Replacement
O que você precisa
  1. Nikon Coolpix 995 LCD Replacement, LCD: passo 1, imagem 1 %32 Nikon Coolpix 995 LCD Replacement, LCD: passo 1, imagem 2 %32
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: passo 2, imagem 1 %32
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: passo 3, imagem 1 %32
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: passo 4, imagem 1 %32 Nikon Coolpix 995 LCD Replacement: passo 4, imagem 2 %32
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: passo 5, imagem 1 %32
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: passo 6, imagem 1 %32
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
Conclusão
Cory Layman
Membro desde: 10/04/11
93 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team 1-5, Zhou Fall 2011 Membro de UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 2,765
