Ir para o conteúdo principal
Nikon Coolpix 7900 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix 7900 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 LCD Screen Replacement: passo 4, imagem 1 %32
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 LCD Screen Replacement: passo 5, imagem 1 %32
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 LCD Screen Replacement: passo 6, imagem 1 %32
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
  7. Nikon Coolpix 7900 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32
    • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
    • Carefully flip the screen down to reveal the back of the screen
  8. Nikon Coolpix 7900 LCD Screen Replacement: passo 8, imagem 1 %32
    • Disconnect the ribbon cable and gray connector with red and black wires.
    • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
Conclusão
Uma outra pessoa concluiu este guia.
Kaky Payne
Membro desde: 04/17/12
121 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-38, Regan Spring 2012 Membro de Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 1,780
