Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Use this guide to replace the front cover.
Peças
Nenhum componente especificado.
  1. Remove the four 3.0mm screws on the bottom of the camera.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Remove the two 3.0mm screws on the right side of the camera.
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  5. Carefully open the back cover. Take care as there are connectors still attached.
    • Carefully open the back cover. Take care as there are connectors still attached.
  6. Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  7. Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
  8. Be careful of metallic parts which are loose and will fall out.
    • Be careful of metallic parts which are loose and will fall out.
    • Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
  9. Remove the two 3.0mm screws on the right side of the camera.
  10. Remove front cover.
    • Remove front cover.
Conclusão
Kaky Payne
Membro desde: 17-04-2012
58 Reputação
5 Guias de autoria
equipe
Cal Poly, Team 12-38, Regan Spring 2012 Membro de Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,140
