Ir para o conteúdo principal
Nikon Coolpix 775 Screen Replacement
O que você precisa
  1. Nikon Coolpix 775 Screen Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix 775 Screen Replacement, Battery: passo 1, imagem 2 %32 Nikon Coolpix 775 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 2, imagem 2 %32
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Screen Replacement: passo 3, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 3, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 3, imagem 3 %32
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Screen Replacement, Motherboard: passo 4, imagem 1 %32 Nikon Coolpix 775 Screen Replacement, Motherboard: passo 4, imagem 2 %32 Nikon Coolpix 775 Screen Replacement, Motherboard: passo 4, imagem 3 %32
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Screen Replacement: passo 5, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 5, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 5, imagem 3 %32
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Screen Replacement: passo 6, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 6, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 6, imagem 3 %32
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Screen Replacement: passo 7, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 7, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 7, imagem 3 %32
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Screen Replacement: passo 8, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 8, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 8, imagem 3 %32
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Screen Replacement: passo 9, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 9, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 9, imagem 3 %32
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Screen Replacement: passo 10, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 10, imagem 2 %32
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Screen Replacement: passo 11, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 11, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 11, imagem 3 %32
    • Pull the ribbon connected to the dial off the motherboard.
  12. Nikon Coolpix 775 Screen Replacement, Screen: passo 12, imagem 1 %32 Nikon Coolpix 775 Screen Replacement, Screen: passo 12, imagem 2 %32
    • Remove the orange ribbon cable from its connector by firmly but gently pulling it.
  13. Nikon Coolpix 775 Screen Replacement: passo 13, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 13, imagem 2 %32
    • Pull out the pink cable connector.
    • If it's not coming loose, use a pair of needle nose pliers to get a good grip on the connector.
  14. Nikon Coolpix 775 Screen Replacement: passo 14, imagem 1 %32 Nikon Coolpix 775 Screen Replacement: passo 14, imagem 2 %32 Nikon Coolpix 775 Screen Replacement: passo 14, imagem 3 %32
    • Grab the back of the screen and gently lift up.
    • It is only held on by adhesive so it should come out relatively easy.
Conclusão
Nick Meador
Membro desde: 11/05/18
97 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G3, Baechle Fall 2018 Membro de IUPUI, Team S2-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 201
