Ir para o conteúdo principal
Nikon Coolpix 5400 Battery Replacement
O que você precisa
  1. Nikon Coolpix 5400 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: passo 2, imagem 1 %32 Nikon Coolpix 5400 Battery Replacement: passo 2, imagem 2 %32
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: passo 3, imagem 1 %32
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 404
