Ir para o conteúdo principal
Nikon Coolpix 3500 Front Cover Replacement.
O que você precisa
  1. Nikon Coolpix 3500 Front Cover Replacement., Battery: passo 1, imagem 1 %32
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 Front Cover Replacement., Front Cover: passo 2, imagem 1 %32
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Front Cover Replacement.: passo 3, imagem 1 %32
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Front Cover Replacement.: passo 4, imagem 1 %32
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Front Cover Replacement.: passo 5, imagem 1 %32
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Front Cover Replacement.: passo 6, imagem 1 %32 Nikon Coolpix 3500 Front Cover Replacement.: passo 6, imagem 2 %32
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Front Cover Replacement.: passo 7, imagem 1 %32 Nikon Coolpix 3500 Front Cover Replacement.: passo 7, imagem 2 %32
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
Conclusão
richard guenther
Membro desde: 04/19/10
183 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 30-38, Garner Spring 2010 Membro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 1,900
