Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Replacing the front cover of a Nikon Coolpix 3500.
Peças
Nenhum componente especificado.
  1. Unlatch the battery cover. Slide the cover out and flip it open.
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Remove the two 4.5 mm screws that sit inside the battery slot.
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  6. Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  7. Remove the five 3.5 mm screws that sit at the bottom of the camera. Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the logic board.
  8. Using a spudger, detach the white-capped wire. Using a spudger, detach the orange-capped wire and set the front cover aside.
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
Conclusão
richard guenther
Membro desde: 19-04-2010
183 Reputação
6 Guias de autoria
equipe
Cal Poly, Team 30-38, Garner Spring 2010 Membro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,709
