Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing the logic board of a Nikon Coolpix 3500
O que você precisa
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Detach the grey-capped wire.
Detach the green chip that sits next to the blue wires.
