Introdução
Replacing the logic board of a Nikon Coolpix 3500
Ferramentas
Peças
Nenhum componente especificado.
Unlatch the battery cover. Slide the cover out and flip it open.
Remove the battery.
Gently remove the battery cover.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Detach the grey-capped wire.
Detach the green chip that sits next to the blue wires.
Quase terminado!
Conclusão
