Ir para o conteúdo principal
Nikon CoolPix S600 Lens Assembly Replacement
O que você precisa
  1. Nikon CoolPix S600 Lens Assembly Replacement, Front and Rear Casing: passo 1, imagem 1 %32
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Lens Assembly Replacement: passo 2, imagem 1 %32
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Lens Assembly Replacement: passo 3, imagem 1 %32
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Lens Assembly Replacement: passo 4, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 4, imagem 2 %32
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Lens Assembly Replacement: passo 5, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 5, imagem 2 %32
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Lens Assembly Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Lens Assembly Replacement: passo 8, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 8, imagem 2 %32
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Lens Assembly Replacement: passo 9, imagem 1 %32
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Lens Assembly Replacement: passo 10, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 10, imagem 2 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 10, imagem 3 %32
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: passo 11, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: passo 11, imagem 2 %32
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Lens Assembly Replacement: passo 12, imagem 1 %32
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Lens Assembly Replacement: passo 13, imagem 1 %32
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Lens Assembly Replacement: passo 14, imagem 1 %32
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Lens Assembly Replacement: passo 15, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 15, imagem 2 %32
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Lens Assembly Replacement: passo 16, imagem 1 %32 Nikon CoolPix S600 Lens Assembly Replacement: passo 16, imagem 2 %32
    • Gently separate the camera lens from the mother board.
Conclusão
Equipe
Cuesta, Team 1-6, Zipperian Fall 2011 Membro de Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
Membros da 2
Autoria de 6 guias
Um comentário
Any place where I could buy a new lens for the camera nowadays?
thesilver - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 3,251
