Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Remove the chrome side cover from the body of the camera.
    • Remove the chrome side cover from the body of the camera.
  3. Remove the four 3.2 mm screws on the bottom of the camera.
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Use the tweezers to disconnect the ribbon from the circuit board.
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  9. Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  10. Remove the two 3.2 mm screws that hold the flash to the front cover.
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  11. Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  12. From the top view of the camera, remove the one 5.8 mm screw. From the top view of the camera, remove the one 2.8 mm screw
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  13. Remove the three 3.4 mm screws from the back side of the camera.
    • Remove the three 3.4 mm screws from the back side of the camera.
  14. Remove the two 3.4 mm screws from the side of the camera.
    • Remove the two 3.4 mm screws from the side of the camera.
  15. Separate the two metal body pieces from the rest of the camera.
    • Separate the two metal body pieces from the rest of the camera.
  16. Gently remove the two ribbons connecting the lens to the mother board. Gently remove the two ribbons connecting the lens to the mother board.
    • Gently remove the two ribbons connecting the lens to the mother board.
  17. Gently separate the camera lens from the mother board. Gently separate the camera lens from the mother board.
    • Gently separate the camera lens from the mother board.
Conclusão
2 outras pessoas concluíram este guia.
andreas anggasastra
Membro desde: 14-09-2011
116 Reputação
5 Guias de autoria
equipe
Cuesta, Team 1-6, Zipperian Fall 2011 Membro de Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Membros
5 Guias de autoria
Any place where I could buy a new lens for the camera nowadays?
thesilver - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,957
