Ir para o conteúdo principal
Nikon CoolPix S600 Front and Rear Casing Replacement
O que você precisa
  1. Nikon CoolPix S600 Front and Rear Casing Replacement, Front and Rear Casing: passo 1, imagem 1 %32
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 2, imagem 1 %32
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 3, imagem 1 %32
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 4, imagem 1 %32 Nikon CoolPix S600 Front and Rear Casing Replacement: passo 4, imagem 2 %32
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 5, imagem 1 %32 Nikon CoolPix S600 Front and Rear Casing Replacement: passo 5, imagem 2 %32
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 6, imagem 1 %32
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 7, imagem 1 %32
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 8, imagem 1 %32 Nikon CoolPix S600 Front and Rear Casing Replacement: passo 8, imagem 2 %32
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 9, imagem 1 %32
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Front and Rear Casing Replacement: passo 10, imagem 1 %32 Nikon CoolPix S600 Front and Rear Casing Replacement: passo 10, imagem 2 %32 Nikon CoolPix S600 Front and Rear Casing Replacement: passo 10, imagem 3 %32
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
Conclusão
Equipe
Cuesta, Team 1-6, Zipperian Fall 2011 Membro de Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,251
