Ir para o conteúdo principal
Nikon CoolPix S5 Wrist Strap Holder Replacement
O que você precisa
  1. Nikon CoolPix S5 Wrist Strap Holder Replacement, Wrist Strap Holder: passo 1, imagem 1 %32
    • Remove the wrist strap from the wrist strap holder by untying the string at the end of the wrist strap.
    • This will allow for the wrist strap to be pulled through the wrist strap holder.
  2. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 2, imagem 1 %32
    • Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
    • This will cause the Battery/SD cover to pop open.
  3. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 3, imagem 1 %32
    • Use the Phillips screwdriver to remove the four screws on the bottom of the camera.
  4. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 4, imagem 1 %32
    • Using fingers, pull the silver side panels from each side.
  5. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 5, imagem 1 %32
    • On the right hand side of the camera, remove the two screws from the wrist strap handle by using the Phillips screwdriver.
Conclusão
Equipe
Clemson, Team 12-5, Benson Spring 2013 Membro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 541
