Introdução
This guide is to be used to install the plastic LCD screen cover in the case that it becomes damaged or no longer functions properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
O que você precisa
Press lightly on the outer surface of the plastic LCD screen cover in each corner.
The plastic LCD screen cover should pop out of the back plate.
