Ir para o conteúdo principal
Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
O que você precisa
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 2, imagem 1 %32
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 3, imagem 1 %32 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 3, imagem 2 %32
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 4, imagem 1 %32 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 4, imagem 2 %32
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 5, imagem 1 %32 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 5, imagem 2 %32
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 6, imagem 1 %32 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 6, imagem 2 %32
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: passo 7, imagem 1 %32 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: passo 7, imagem 2 %32
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
Conclusão
Josh Miller
Membro desde: 03/11/13
87 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 12-5, Benson Spring 2013 Membro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 421
