Introdução
Your Nikon Coolpix S5 has buttons on the back that control the operation of the camera. These buttons can become damaged or loose, which makes it hard to use the camera. This guide explains how to open the back of the camera and install replacement buttons.
Disconnect the camera from its charger before beginning this repair.
O que você precisa
The plate holding the buttons is on the right side of the camera. Use your fingers to open it to the right, away from the LCD screen. Do not twist or force the panel open. It should lift easily.
3 outras pessoas executaram este guia.
