Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide is to be used to install the battery in the case that the battery dies or no longer functions properly. A Phillips screwdriver will be needed to complete this installation.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Press orange clip to eject battery (battery not shown).
    • Press orange clip to eject battery (battery not shown).
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  5. Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  6. Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Conclusão
3 outras pessoas concluíram este guia.
Patty Richeson
Membro desde: 11-03-2013
75 Reputação
4 Guias de autoria
equipe
Clemson, Team 12-5, Benson Spring 2013 Membro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membros
7 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 400
