Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Sometimes, dust appear on all your pictures. It may only be a dust on the sensor. It's quite quick to remove. To check if the issue is coming from a sensor dust, you must have a blurry dot on all your pictures, that may or may not change in size and shape with different aperture. Check first that the dust is not on the lens.
Peças
Nenhum componente especificado.
    • Remove all screws from the bottom, sides and top of the camera. All screws don't have the same size, be careful when replacing them.
    • Pull gently but firmly the back cover of the camera to remove it and reveal the inside.
  1. Remove the plastic part with all buttons. Lift up the  the buttons block from the left side, to access its ZIF connector. Lift up the  the buttons block from the left side, to access its ZIF connector.
    • Remove the plastic part with all buttons.
    • Lift up the the buttons block from the left side, to access its ZIF connector.
  2. With a plastic spudger, open the ZIF connector and release the button block. It opens from the right side - the black part is to be gently lifted up. With a plastic spudger, open the ZIF connector and release the button block. It opens from the right side - the black part is to be gently lifted up.
    • With a plastic spudger, open the ZIF connector and release the button block. It opens from the right side - the black part is to be gently lifted up.
  3. Lift up the screen from the left side, to access its two ZIF connectors. Open the small and the large ZIF connectors with a spudger. The small connector is opened by lifting the black part.
    • Lift up the screen from the left side, to access its two ZIF connectors.
    • Open the small and the large ZIF connectors with a spudger.
    • The small connector is opened by lifting the black part.
    • The large connector is released thanks to the orange part. This longer connector needs to be opened carefully.
  4. Remove the screws maintaining the last metal protection. Remove the screws maintaining the last metal protection.
    • Remove the screws maintaining the last metal protection.
  5. Remove the 3 screws to release the image sensor PCB. Release the ZIF connector lifting it up gently using a plastic spudger. You can then remove the image sensor and clean it. Avoid to scratch the sensor or the inner lens glass, as these would be unrepairable damages.
    • Remove the 3 screws to release the image sensor PCB.
    • Release the ZIF connector lifting it up gently using a plastic spudger.
    • You can then remove the image sensor and clean it. Avoid to scratch the sensor or the inner lens glass, as these would be unrepairable damages.
Conclusão
Mipam
Membro desde: 20/06/2015
453 Reputação
Autoria de 1 guia
Equipe
6337 - Réparer l'irréparable Membro de 6337 - Réparer l'irréparable
Business
1 Membro
1 Guia de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 228
