Ir para o conteúdo principal
Nikon COOLPIX S610c Motherboard Replacement
O que você precisa
  1. Nikon COOLPIX S610c Motherboard Replacement, Rear Casing: passo 1, imagem 1 %32
    • Remove the three 3x3mm screws attached to the rear casing.
  2. Nikon COOLPIX S610c Motherboard Replacement: passo 2, imagem 1 %32
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  3. Nikon COOLPIX S610c Motherboard Replacement: passo 3, imagem 1 %32
    • Pry the panel off from the bottom using your fingernail.
  4. Nikon COOLPIX S610c Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  5. Nikon COOLPIX S610c Motherboard Replacement: passo 5, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  6. Nikon COOLPIX S610c Motherboard Replacement: passo 6, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 6, imagem 2 %32
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  7. Nikon COOLPIX S610c Motherboard Replacement: passo 7, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 7, imagem 2 %32
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  8. Nikon COOLPIX S610c Motherboard Replacement, Front Casing: passo 8, imagem 1 %32
    • Remove the three 3x3mm screws that attach the front casing to the bottom.
  9. Nikon COOLPIX S610c Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
  10. Nikon COOLPIX S610c Motherboard Replacement: passo 10, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 10, imagem 2 %32
    • Lift the back panel off the motherboard.
    • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
  11. Nikon COOLPIX S610c Motherboard Replacement: passo 11, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 11, imagem 2 %32
    • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
    • Note that the white ribbon connector latch flips away from the ribbon cable.
  12. Nikon COOLPIX S610c Motherboard Replacement: passo 12, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the final 4x3mm screw at the top of the camera near the lens.
  13. Nikon COOLPIX S610c Motherboard Replacement: passo 13, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement: passo 13, imagem 2 %32
    • Pry the front casing away from the body of the camera.
    • Be careful not to damage the wires that attach the front panel to the motherboard.
    • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
  14. Nikon COOLPIX S610c Motherboard Replacement: passo 14, imagem 1 %32
    • Unscrew the three 3x2mm screws that attach the cables to the front casing.
  15. Nikon COOLPIX S610c Motherboard Replacement, Lens Assembly: passo 15, imagem 1 %32 Nikon COOLPIX S610c Motherboard Replacement, Lens Assembly: passo 15, imagem 2 %32
    • Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
    • Take note that the ribbon connector pulls away from the ribbon.
  16. Nikon COOLPIX S610c Motherboard Replacement, Motherboard: passo 16, imagem 1 %32
    • Once the lens assembly has been removed, the mother board cannot be disassembled any further.
Conclusão
Kevin Backers
Membro desde: 01/26/12
301 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-5, Regan Winter 2012 Membro de Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 14
Duração total: 524
