Ir para o conteúdo principal
Nikon COOLPIX S610c LCD Replacement
O que você precisa
  1. Nikon COOLPIX S610c LCD Replacement, Battery: passo 1, imagem 1 %32
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c LCD Replacement: passo 2, imagem 1 %32
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c LCD Replacement: passo 3, imagem 1 %32
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c LCD Replacement, Rear Casing: passo 4, imagem 1 %32
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c LCD Replacement: passo 5, imagem 1 %32
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c LCD Replacement: passo 6, imagem 1 %32
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c LCD Replacement: passo 7, imagem 1 %32
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c LCD Replacement: passo 8, imagem 1 %32 Nikon COOLPIX S610c LCD Replacement: passo 8, imagem 2 %32
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c LCD Replacement: passo 9, imagem 1 %32 Nikon COOLPIX S610c LCD Replacement: passo 9, imagem 2 %32
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c LCD Replacement: passo 10, imagem 1 %32 Nikon COOLPIX S610c LCD Replacement: passo 10, imagem 2 %32
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c LCD Replacement, LCD: passo 11, imagem 1 %32 Nikon COOLPIX S610c LCD Replacement, LCD: passo 11, imagem 2 %32
    • Pry the display from the rear casing using a spudger.
Conclusão
Kevin Backers
Membro desde: 01/26/12
304 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-5, Regan Winter 2012 Membro de Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 717
