Ir para o conteúdo principal
Nikon COOLPIX S3600 SD Card Replacement
  1. Nikon COOLPIX S3600 SD Card Replacement, SD Card: passo 1, imagem 1 %32 Nikon COOLPIX S3600 SD Card Replacement, SD Card: passo 1, imagem 2 %32
    • Push latch downwards to open the battery hatch located on the bottom right.
    • Memory card is located above the battery compartment.
  2. Nikon COOLPIX S3600 SD Card Replacement: passo 2, imagem 1 %32 Nikon COOLPIX S3600 SD Card Replacement: passo 2, imagem 2 %32 Nikon COOLPIX S3600 SD Card Replacement: passo 2, imagem 3 %32
    • Push in the memory card until you can't push it in any more and release.
    • Memory card should be slightly popped up.
    • Now you can carefully remove the memory card.
Conclusão
Lenisha Poirier
Membro desde: 03/16/15
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 57
Duração total: 3,015
