Introdução
This guide showcases how to replace the focusing screen on the Nikon COOLPIX p7700 camera. Follow these 18 steps to ensure proper replacement of the camera's focusing lens.
O que você precisa
Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
Remove the side panel.
Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
2 comentários
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
