Ir para o conteúdo principal
Nikon COOLPIX P7700 Focusing Screen Replacement
O que você precisa
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: passo 1, imagem 1 %32 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: passo 1, imagem 2 %32
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 2, imagem 1 %32
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 3, imagem 1 %32
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 4, imagem 1 %32
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 5, imagem 1 %32
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 6, imagem 1 %32 Nikon COOLPIX P7700 Focusing Screen Replacement: passo 6, imagem 2 %32
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 7, imagem 1 %32
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: passo 8, imagem 1 %32
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 9, imagem 1 %32
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 10, imagem 1 %32 Nikon COOLPIX P7700 Focusing Screen Replacement: passo 10, imagem 2 %32 Nikon COOLPIX P7700 Focusing Screen Replacement: passo 10, imagem 3 %32
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 11, imagem 1 %32 Nikon COOLPIX P7700 Focusing Screen Replacement: passo 11, imagem 2 %32
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 12, imagem 1 %32 Nikon COOLPIX P7700 Focusing Screen Replacement: passo 12, imagem 2 %32
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 13, imagem 1 %32
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 14, imagem 1 %32
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 15, imagem 1 %32
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 16, imagem 1 %32
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: passo 17, imagem 1 %32
    • Remove the lens from the camera.
Conclusão
Dustin Wahl
Membro desde: 03/11/15
775 Reputação
Autoria de 4 guias
Equipe
Colorado Springs, Team 2-7, Panko Spring 2015 Membro de Colorado Springs, Team 2-7, Panko Spring 2015
UCCS-PANKO-S15S2G7
Membros da 3
Autoria de 10 guias
2 comentários
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - Responder
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 1,716
