Ir para o conteúdo principal
Nikon COOLPIX P7700 Back Casing Replacement
O que você precisa
  1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: passo 1, imagem 1 %32 Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: passo 1, imagem 2 %32
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Back Casing Replacement: passo 2, imagem 1 %32
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Back Casing Replacement: passo 3, imagem 1 %32
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Back Casing Replacement: passo 4, imagem 1 %32
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Back Casing Replacement: passo 5, imagem 1 %32
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Back Casing Replacement: passo 6, imagem 1 %32 Nikon COOLPIX P7700 Back Casing Replacement: passo 6, imagem 2 %32
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Back Casing Replacement: passo 7, imagem 1 %32
    • Remove the back casing.
Conclusão
Dustin Wahl
Membro desde: 03/11/15
775 Reputação
Autoria de 4 guias
Equipe
Colorado Springs, Team 2-7, Panko Spring 2015 Membro de Colorado Springs, Team 2-7, Panko Spring 2015
UCCS-PANKO-S15S2G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,770
