Ir para o conteúdo principal
Nikon COOLPIX P600 Battery Replacement
  1. Nikon COOLPIX P600 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: passo 2, imagem 1 %32 Nikon COOLPIX P600 Battery Replacement: passo 2, imagem 2 %32
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: passo 3, imagem 1 %32 Nikon COOLPIX P600 Battery Replacement: passo 3, imagem 2 %32
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
Documentos anexados
Equipe
CSU Fullerton, Team 1-5, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-5, Bruce Fall 2015
CSUF-BRUCE-F15S1G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 26
Duração total: 2,103
