Ir para o conteúdo principal
Nikon COOLPIX P500 Rear Case Replacement
O que você precisa
  1. Nikon COOLPIX P500 Rear Case Replacement, Battery: passo 1, imagem 1 %32 Nikon COOLPIX P500 Rear Case Replacement, Battery: passo 1, imagem 2 %32
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Rear Case Replacement, Rear Case: passo 2, imagem 1 %32 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: passo 2, imagem 2 %32 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: passo 2, imagem 3 %32
    • Remove the marked 3mm screws.
    • Separate the two parts of the body of the camera slightly.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
  3. Nikon COOLPIX P500 Rear Case Replacement: passo 3, imagem 1 %32
    • Remove the labeled 3mm screws using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Rear Case Replacement: passo 4, imagem 1 %32
    • Remove the brown metal plate.
Conclusão
Kevin Scott
Membro desde: 01/22/15
529 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-10, Maness Winter 2015 Membro de Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,267
