Ir para o conteúdo principal
Nikon COOLPIX P500 Motherboard Replacement
O que você precisa
  1. Nikon COOLPIX P500 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Motherboard Replacement, Motherboard: passo 2, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement, Motherboard: passo 2, imagem 2 %32 Nikon COOLPIX P500 Motherboard Replacement, Motherboard: passo 2, imagem 3 %32
    • Remove all the marked screws using a PH00 screwdriver.
    • Remove the two 3mm screws on the grip.
    • Remove the two 4mm screws on the side opposite the grip.
    • Remove the three 4mm screws on the base of the camera.
    • Remove the four 3mm screws on the base of the camera.
  3. Nikon COOLPIX P500 Motherboard Replacement, Removing hidden screws: passo 3, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement, Removing hidden screws: passo 3, imagem 2 %32
    • Open the flash module of the camera.
    • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
    • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Motherboard Replacement: passo 4, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 4, imagem 2 %32
    • Separate the two parts of the body of the camera slightly.
    • Release the two cables by lifting up their respective clips with a spudger.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
    • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
  5. Nikon COOLPIX P500 Motherboard Replacement: passo 5, imagem 1 %32
    • Use a spudger to flip up the cable lock in order to release the ribbon.
  6. Nikon COOLPIX P500 Motherboard Replacement: passo 6, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 6, imagem 2 %32
    • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
    • Remove the four labeled 4mm screws connected to the motherboard.
    • Remove the metal support.
  7. Nikon COOLPIX P500 Motherboard Replacement: passo 7, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 7, imagem 2 %32
    • Desolder the labeled soldering points.
    • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
  8. Nikon COOLPIX P500 Motherboard Replacement: passo 8, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 8, imagem 2 %32
  9. Nikon COOLPIX P500 Motherboard Replacement: passo 9, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 9, imagem 2 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 9, imagem 3 %32
    • Use a spudger to unlock the labeled connector ribbons.
    • Disconnect the labeled connector ribbons.
  10. Nikon COOLPIX P500 Motherboard Replacement: passo 10, imagem 1 %32 Nikon COOLPIX P500 Motherboard Replacement: passo 10, imagem 2 %32
    • Use a spudger to unlock the two connector ribbons.
    • Disconnect the two connector ribbons.
  11. Nikon COOLPIX P500 Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the mother board from the camera.
Conclusão
3 outras pessoas executaram este guia.
Carmen Dang
Membro desde: 01/28/15
385 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-10, Maness Winter 2015 Membro de Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 37
Duração total: 4,982
