Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the screw located near the speaker port using a Phillips 00 screwdriver.
Turn camera upside down so that the battery compartment is facing you.
Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
Rotate the camera to the opposite side where the A/V outlet is located.
Unscrew and remove all four screws with a Phillips 00 screwdriver.
Turn the camera so that the Wi-Fi adapter is facing you.
Using a plastic opening tool, pry the front casing of the camera.
Continue this motion all around the front casing of the camera.
Gently pull apart the front casing from the rest of the camera.
Using the plastic opening tool pry the back casing of the camera.
Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
Pull apart the orange ribbon and front casing from the rest of the camera.
