Introdução
This replacement may be necessary if all other options have been exhausted.
  1. Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device. Remove the screws under the flaps covering the HDMI and mini USB ports.
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
  2. Carefully pry back the back plate.
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
  6. Use the plastic opening tool to pry off the connectors shown Using your finger, pry off the connection flap. Using your finger, pry off the connection flap.
    • Use the plastic opening tool to pry off the connectors shown
    • Using your finger, pry off the connection flap.
  7. Using tweezers, pull out the shown connectors Using tweezers, pull out the shown connectors Using tweezers, pull out the shown connectors
    • Using tweezers, pull out the shown connectors
  8. Pull back the black switches holding the connecting ribbons in place, and pull out the ribbons.
    • Pull back the black switches holding the connecting ribbons in place, and pull out the ribbons.
    • Remove the motherboard.
Conclusão
Austin Lackey
455 reputação
4 Guides authored
Equipe
USF Tampa, Team S11-G4, Passmore Fall 2017 Membro de USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Membros
4 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Todo: 282
