Ir para o conteúdo principal
Nike SportWatch GPS Unit Replacement
O que você precisa
  1. Nike SportWatch GPS Unit Replacement, GPS Unit: passo 1, imagem 1 %32
    • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
  2. Nike SportWatch GPS Unit Replacement: passo 2, imagem 1 %32
    • Then, gently pull the watch band and front screen apart.
  3. Nike SportWatch GPS Unit Replacement: passo 3, imagem 1 %32
    • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
  4. Nike SportWatch GPS Unit Replacement: passo 4, imagem 1 %32
    • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS Unit Replacement: passo 5, imagem 1 %32
    • Use a spudger, to remove the orange tape that covers the wire for the GPS.
  6. Nike SportWatch GPS Unit Replacement: passo 6, imagem 1 %32
    • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
    • When you are reassembling the watch, you will have to solder the wire back together.
  7. Nike SportWatch GPS Unit Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to pry out the GPS unit.
Conclusão
Uma outra pessoa concluiu este guia.
Ian Eichorn
Membro desde: 10/22/15
678 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
Membros da 3
Autoria de 5 guias
3 comentários
which GPS unit is it?
charles - Responder
what gps unit is it?
charles - Responder
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,878
