Ir para o conteúdo principal
Nike+ Sportband Screen Replacement
O que você precisa
  1. Nike+ Sportband Screen Replacement, External Case: passo 1, imagem 1 %32 Nike+ Sportband Screen Replacement, External Case: passo 1, imagem 2 %32
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Screen Replacement: passo 2, imagem 1 %32 Nike+ Sportband Screen Replacement: passo 2, imagem 2 %32
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Screen Replacement, Screen: passo 3, imagem 1 %32 Nike+ Sportband Screen Replacement, Screen: passo 3, imagem 2 %32
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Screen Replacement: passo 4, imagem 1 %32 Nike+ Sportband Screen Replacement: passo 4, imagem 2 %32 Nike+ Sportband Screen Replacement: passo 4, imagem 3 %32
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Screen Replacement: passo 5, imagem 1 %32 Nike+ Sportband Screen Replacement: passo 5, imagem 2 %32
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Screen Replacement: passo 6, imagem 1 %32 Nike+ Sportband Screen Replacement: passo 6, imagem 2 %32 Nike+ Sportband Screen Replacement: passo 6, imagem 3 %32
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
Conclusão
Daniel Burtner
Membro desde: 02/15/16
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 9-9, Wilson Spring 2016 Membro de IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
Membros da 5
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 237
