Ir para o conteúdo principal
Nexus S Rear Camera Replacement
O que você precisa
  1. Nexus S Rear Camera Replacement, Rear Panel: passo 1, imagem 1 %32
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Rear Camera Replacement: passo 2, imagem 1 %32
    • Remove the rear panel from the Nexus S.
  3. Nexus S Rear Camera Replacement, Battery: passo 3, imagem 1 %32
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Rear Camera Replacement, SIM Card: passo 4, imagem 1 %32 Nexus S Rear Camera Replacement, SIM Card: passo 4, imagem 2 %32
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Rear Camera Replacement, Rear Inner Frame: passo 5, imagem 1 %32
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Rear Camera Replacement: passo 6, imagem 1 %32
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Rear Camera Replacement: passo 7, imagem 1 %32 Nexus S Rear Camera Replacement: passo 7, imagem 2 %32
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Rear Camera Replacement: passo 8, imagem 1 %32 Nexus S Rear Camera Replacement: passo 8, imagem 2 %32
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Rear Camera Replacement: passo 9, imagem 1 %32
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Rear Camera Replacement: passo 10, imagem 1 %32
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Rear Camera Replacement, SIM Card Board: passo 11, imagem 1 %32
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S Rear Camera Replacement: passo 12, imagem 1 %32 Nexus S Rear Camera Replacement: passo 12, imagem 2 %32 Nexus S Rear Camera Replacement: passo 12, imagem 3 %32
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S Rear Camera Replacement: passo 13, imagem 1 %32
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S Rear Camera Replacement, Motherboard: passo 14, imagem 1 %32
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
  15. Nexus S Rear Camera Replacement: passo 15, imagem 1 %32
    • Repeat the same procedure as the previous step to disconnect the digitizer connector.
  16. Nexus S Rear Camera Replacement: passo 16, imagem 1 %32
    • Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
    • Remove the three Phillips screws securing the motherboard to the inner assembly.
  17. Nexus S Rear Camera Replacement: passo 17, imagem 1 %32
    • Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
  18. Nexus S Rear Camera Replacement, Rear Camera: passo 18, imagem 1 %32 Nexus S Rear Camera Replacement, Rear Camera: passo 18, imagem 2 %32
    • Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
  19. Nexus S Rear Camera Replacement: passo 19, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to lift and remove the rear camera from the motherboard.
Conclusão
7 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 3,254
