Ir para o conteúdo principal
Nexus S Front Panel Assembly Replacement
O que você precisa
  1. Nexus S Front Panel Assembly Replacement, Rear Panel: passo 1, imagem 1 %32
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Front Panel Assembly Replacement: passo 2, imagem 1 %32
    • Remove the rear panel from the Nexus S.
  3. Nexus S Front Panel Assembly Replacement, Battery: passo 3, imagem 1 %32
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Front Panel Assembly Replacement, SIM Card: passo 4, imagem 1 %32 Nexus S Front Panel Assembly Replacement, SIM Card: passo 4, imagem 2 %32
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Front Panel Assembly Replacement, Rear Inner Frame: passo 5, imagem 1 %32
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Front Panel Assembly Replacement: passo 6, imagem 1 %32
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Front Panel Assembly Replacement: passo 7, imagem 1 %32 Nexus S Front Panel Assembly Replacement: passo 7, imagem 2 %32
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Front Panel Assembly Replacement: passo 8, imagem 1 %32 Nexus S Front Panel Assembly Replacement: passo 8, imagem 2 %32
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Front Panel Assembly Replacement: passo 9, imagem 1 %32
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Front Panel Assembly Replacement: passo 10, imagem 1 %32
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Front Panel Assembly Replacement, Motherboard: passo 11, imagem 1 %32
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  12. Nexus S Front Panel Assembly Replacement: passo 12, imagem 1 %32 Nexus S Front Panel Assembly Replacement: passo 12, imagem 2 %32 Nexus S Front Panel Assembly Replacement: passo 12, imagem 3 %32
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  13. Nexus S Front Panel Assembly Replacement: passo 13, imagem 1 %32
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  14. Nexus S Front Panel Assembly Replacement: passo 14, imagem 1 %32 Nexus S Front Panel Assembly Replacement: passo 14, imagem 2 %32
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
  15. Nexus S Front Panel Assembly Replacement, Front Panel Assembly: passo 15, imagem 1 %32
    • Front panel assembly remains.
Conclusão
17 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 14,445
