Ir para o conteúdo principal
Nexus One Vibrator Replacement
O que você precisa
  1. Nexus One Vibrator Replacement, Lower Cover: passo 1, imagem 1 %32 Nexus One Vibrator Replacement, Lower Cover: passo 1, imagem 2 %32
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Nexus One Vibrator Replacement, Antenna Housing: passo 2, imagem 1 %32
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    • The vibrator is located on the back of the antenna housing.
    • Use the spudger to pry up on the axle of the motor.
Conclusão
Niklas Johnson
Membro desde: 01/31/12
1.207 Reputação
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 1,689
