Introdução
removing the lower cover
O que você precisa
Using the plastic opening tool, push the blade into the space between the case and lower cover.
Turn the opening tool slightly, the lower cover will detach on that side.
Repeat on other side of the seam.
The lower cover will slide off.
3 outras pessoas executaram este guia.
