Ir para o conteúdo principal
Nexus One Front Speaker Replacement
O que você precisa
  1. Nexus One Front Speaker Replacement, Rear Cover: passo 1, imagem 1 %32 Nexus One Front Speaker Replacement, Rear Cover: passo 1, imagem 2 %32
    • Using two fingers, push up on the rear cover.
  2. Nexus One Front Speaker Replacement: passo 2, imagem 1 %32
    • The rear cover slides up and off.
  3. Nexus One Front Speaker Replacement, Battery: passo 3, imagem 1 %32
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Front Speaker Replacement: passo 4, imagem 1 %32
    • Pull the battery up and out.
  5. Nexus One Front Speaker Replacement, Battery Housing: passo 5, imagem 1 %32
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Front Speaker Replacement: passo 6, imagem 1 %32 Nexus One Front Speaker Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Front Speaker Replacement: passo 7, imagem 1 %32 Nexus One Front Speaker Replacement: passo 7, imagem 2 %32
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Front Speaker Replacement: passo 8, imagem 1 %32 Nexus One Front Speaker Replacement: passo 8, imagem 2 %32
    • Pry the top tab of the battery housing.
  9. Nexus One Front Speaker Replacement: passo 9, imagem 1 %32 Nexus One Front Speaker Replacement: passo 9, imagem 2 %32
    • Pry the right side tab of the battery housing.
  10. Nexus One Front Speaker Replacement: passo 10, imagem 1 %32 Nexus One Front Speaker Replacement: passo 10, imagem 2 %32
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Front Speaker Replacement, Motherboards: passo 11, imagem 1 %32 Nexus One Front Speaker Replacement, Motherboards: passo 11, imagem 2 %32
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  12. Nexus One Front Speaker Replacement: passo 12, imagem 1 %32 Nexus One Front Speaker Replacement: passo 12, imagem 2 %32 Nexus One Front Speaker Replacement: passo 12, imagem 3 %32
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  13. Nexus One Front Speaker Replacement: passo 13, imagem 1 %32 Nexus One Front Speaker Replacement: passo 13, imagem 2 %32
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  14. Nexus One Front Speaker Replacement: passo 14, imagem 1 %32 Nexus One Front Speaker Replacement: passo 14, imagem 2 %32 Nexus One Front Speaker Replacement: passo 14, imagem 3 %32
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  15. Nexus One Front Speaker Replacement: passo 15, imagem 1 %32
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  16. Nexus One Front Speaker Replacement: passo 16, imagem 1 %32
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  17. Nexus One Front Speaker Replacement: passo 17, imagem 1 %32 Nexus One Front Speaker Replacement: passo 17, imagem 2 %32 Nexus One Front Speaker Replacement: passo 17, imagem 3 %32
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  18. Nexus One Front Speaker Replacement, Front Speaker: passo 18, imagem 1 %32
    • Using the spudger, pop up the end of the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Niklas Johnson
Membro desde: 01/31/12
1.207 Reputação
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 2,304
