Ir para o conteúdo principal
Nexus One Battery Housing Replacement
O que você precisa
  1. Nexus One Battery Housing Replacement, Rear Cover: passo 1, imagem 1 %32 Nexus One Battery Housing Replacement, Rear Cover: passo 1, imagem 2 %32
    • Using two fingers, push up on the rear cover.
  2. Nexus One Battery Housing Replacement: passo 2, imagem 1 %32
    • The rear cover slides up and off.
  3. Nexus One Battery Housing Replacement, Battery: passo 3, imagem 1 %32
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Battery Housing Replacement: passo 4, imagem 1 %32
    • Pull the battery up and out.
  5. Nexus One Battery Housing Replacement, Battery Housing: passo 5, imagem 1 %32
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Battery Housing Replacement: passo 6, imagem 1 %32 Nexus One Battery Housing Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Battery Housing Replacement: passo 7, imagem 1 %32 Nexus One Battery Housing Replacement: passo 7, imagem 2 %32
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Battery Housing Replacement: passo 8, imagem 1 %32 Nexus One Battery Housing Replacement: passo 8, imagem 2 %32
    • Pry the top tab of the battery housing.
  9. Nexus One Battery Housing Replacement: passo 9, imagem 1 %32 Nexus One Battery Housing Replacement: passo 9, imagem 2 %32
    • Pry the right side tab of the battery housing.
  10. Nexus One Battery Housing Replacement: passo 10, imagem 1 %32 Nexus One Battery Housing Replacement: passo 10, imagem 2 %32
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
Conclusão
Niklas Johnson
Membro desde: 01/31/12
1.207 Reputação
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 1,667
