Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
installing the battery housing
  1. Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
  3. Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Pull the battery up and out.
    • Pull the battery up and out.
  5. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  6. Remove the two Torx T5 screws.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  7. Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  8. Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
    • Pry the upper left tab open on the battery housing.
  9. Pry the top tab of the battery housing. Pry the top tab of the battery housing.
    • Pry the top tab of the battery housing.
  10. Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
    • Pry the right side tab of the battery housing.
  11. Pull up on the battery housing. Slide the battery housing out to remove it.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
Conclusão
2 outras pessoas concluíram este guia.
Niklas Johnson
Membro desde: 31-01-2012
1.093 Reputação
18 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,475
