Ir para o conteúdo principal
Nexus 9 Vibrator Replacement
O que você precisa
    1. Nexus 9 Vibrator Replacement, Rear Case: passo 1, imagem 1 %32 Nexus 9 Vibrator Replacement, Rear Case: passo 1, imagem 2 %32 Nexus 9 Vibrator Replacement, Rear Case: passo 1, imagem 3 %32
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Nexus 9 Vibrator Replacement, Vibrator Daughterboard: passo 2, imagem 1 %32
      • Disconnect the two ZIF connectors attached to the daughterboards.
      • Gently pull on the ribbon cable to remove it.
      Pergunte ao FixBot
      Comentar
    2. Nexus 9 Vibrator Replacement: passo 3, imagem 1 %32 Nexus 9 Vibrator Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
      • Use your fingers or a pair of tweezers to remove the bracket.
      Pergunte ao FixBot
      Comentar
    3. Nexus 9 Vibrator Replacement: passo 4, imagem 1 %32 Nexus 9 Vibrator Replacement: passo 4, imagem 2 %32 Nexus 9 Vibrator Replacement: passo 4, imagem 3 %32
      • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
      • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
      • Use your fingers to lift the daughterboard upward and out of the device.
      Pergunte ao FixBot
      Comentar
    4. Nexus 9 Vibrator Replacement: passo 5, imagem 1 %32
      • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
      Pergunte ao FixBot
      Comentar
    1. Nexus 9 Vibrator Replacement, Vibrator: passo 6, imagem 1 %32 Nexus 9 Vibrator Replacement, Vibrator: passo 6, imagem 2 %32
      • Use a pair of tweezers to remove the vibrator from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Geoff Wacker
Membro desde: 09/30/13
92.942 Reputação
Autoria de 88 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 614
