Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replace a faulty or broken USB daughterboard on your Nexus 9.
O que você precisa
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Disconnect the two ZIF connectors attached to the daughterboards.
Gently pull on the ribbon cable to remove it.
Remove the single 3mm T5 Torx screw.
Use a spudger to disconnect the display ribbon cable ZIF connector.
Gently lift the USB daughterboard up from the device.
3 outras pessoas executaram este guia.
